15 years agoVHDL problem?
QUESTION:
Develop a VHDL model for an accumulator that calculates the sum of a sequence of fixed-point numbers. Each input number is signed with 4 pre-binary-point and 12 post-binary-point bits. The accumulated sum has 8 pre-binary-point and 12 post-binary-point bits. A new number arrives at the input during a clock cycle when the data_en control input is 1. The accumulated sum is cleared to 0 when the reset control input is 1. Both control inputs are synchronous. DOUBT: I want to ask how to insert the first input and second input as it using the pre and post numbers? How to store the value for the first input for awhile before it add the second input? The output will light up using LED at the board that we assign it by ourselves. library ieee; use ieee.std_logic_1164.all, ieee.numeric_std.all; entity accumulator is port (clk,reset, data_en : in std_logic; data_in : in signed(15 downto 0); data_out : out signed(19 downto 0) ); end entity accumulator; architecture rtl of accumulator is signal sum, new_sum :signed(19 downto 0); begin new_sum <= sum + resize(data_in, sum'length); reg:process (clk) is begin if rising_edge(clk) then if reset = '1' then sum <= (others => '0'); elsif data_en = '1' then sum <= new_sum; end if; end if; end process reg; data_out <= sum; end architecture rtl; -KYRA-:)17 Replies
The code is very unsynthesisable. The second clock edge is looking for falling edge, and because its inside the rising edge if branch, its basically looking for a rising and falling edge at the same time (so as well as looking for both edges which is impossible in an FPGA, it looks for them simultaneously).
I think when it comes to synthesis we better stick to the proven predictable templates rather than the legality of code. Tools don't always respect the legalities as they are made by low paid software people.
Moreover, the above code will lose the intention as the second edge statement overwrites the first edge. I believe the intention is DDR, so you can use DDR function or your own. - Altera_Forum
--- Quote Start --- Ill open a book on how long before he comes back asking why his code wont compile! --- Quote End --- The nested clock edge condidtion compiles, because it's legal VHDL syntax. But the respective part will be ignored similar to a block under an if false then condition. I'll remember it for interview questions. - Altera_Forum
--- Quote Start --- I have never seen two nested clock edge statements...has vhdl standards changed? --- Quote End --- Ill open a book on how long before he comes back asking why his code wont compile! - Altera_Forum
The problem on this line
is that acc_out is 20 bits and q_reg1 and q_reg2 are 16 bits. The result of the addition is 16 bits and it won't be resized automatically to 20 bits for you. Try something like that instead:acc_out <= q_reg1 + q_reg2;
It is better to increase the size before performing the addition in case you need the 17th bit in the result and prevent an overflow. And by the way,acc_out <= resize(q_reg1,20) + resize(q_reg2,20);
can be replaced byb_reg(8) <= b(8); b_reg(9) <= b(9); b_reg(10) <= b(10); b_reg(11) <= b(11); b_reg(12) <= b(12); b_reg(13) <= b(13); b_reg(14) <= b(14); b_reg(15) <= b(15);b_reg(15 downto 8) <= b(15 downto 8); - Altera_Forum
--- Quote Start --- --this is my code but there are errors.. --the errors are Error (10344): VHDL expression error at acc.vhd(97): expression has 16 elements, but must have 20 elements Error: Can't elaborate top-level user hierarchy Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 2 warnings Error: Peak virtual memory: 183 megabytes Error: Processing ended: Wed Mar 30 08:42:58 2011 Error: Elapsed time: 00:00:01 Error: Total CPU time (on all processors): 00:00:01 Error: Quartus II Full Compilation was unsuccessful. 4 errors, 2 warnings
--can anybody make it correct?? --is this code suitable for board DE1?library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity acc is port ( a: in signed (15 downto 0); b: in signed (15 downto 0); clk: in std_logic; ena: in std_logic; rst: in std_logic; q: out signed (19 downto 0) ) ; end acc; architecture rtl of acc is signal a_reg, b_reg: signed (15 downto 0); signal q_reg1, q_reg2: signed (15 downto 0); signal acc_out: signed (19 downto 0); begin process (clk, rst) begin if (rst = '1') then a_reg <= (others => '0'); b_reg <= (others => '0'); q <= (others => '0'); elsif (clk'event and clk = '1') then a_reg(0) <= a(0); a_reg(1) <= a(1); a_reg(2) <= a(2); a_reg(3) <= a(3); a_reg(4) <= a(4); a_reg(5) <= a(5); a_reg(6) <= a(6); a_reg(7) <= a(7); if (clk'event and clk = '0') then a_reg(8) <= a(8); a_reg(9) <= a(9); a_reg(10) <= a(10); a_reg(11) <= a(11); a_reg(12) <= a(12); a_reg(13) <= a(13); a_reg(14) <= a(14); a_reg(15) <= a(15); q_reg1 <= a_reg; end if; end if; end process; process (ena) begin if (ena = '1') then if (clk'event and clk = '1') then b_reg(0) <= b(0); b_reg(1) <= b(1); b_reg(2) <= b(2); b_reg(3) <= b(3); b_reg(4) <= b(4); b_reg(5) <= b(5); b_reg(6) <= b(6); b_reg(7) <= b(7); end if; if (clk'event and clk = '0') then b_reg(8) <= b(8); b_reg(9) <= b(9); b_reg(10) <= b(10); b_reg(11) <= b(11); b_reg(12) <= b(12); b_reg(13) <= b(13); b_reg(14) <= b(14); b_reg(15) <= b(15); q_reg2 <= b_reg; end if; acc_out <= q_reg1 + q_reg2; end if; end process; q <= acc_out; end rtl; - Altera_Forum
--- Quote Start --- B is your real output --- Quote End --- --this is my code but there are errors.. --the errors are Error (10344): VHDL expression error at acc.vhd(97): expression has 16 elements, but must have 20 elements Error: Can't elaborate top-level user hierarchy Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 2 warnings Error: Peak virtual memory: 183 megabytes Error: Processing ended: Wed Mar 30 08:42:58 2011 Error: Elapsed time: 00:00:01 Error: Total CPU time (on all processors): 00:00:01 Error: Quartus II Full Compilation was unsuccessful. 4 errors, 2 warnings library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity acc is port ( a: in signed (15 downto 0); b: in signed (15 downto 0); clk: in std_logic; ena: in std_logic; rst: in std_logic; q: out signed (19 downto 0) ) ; end acc; architecture rtl of acc is signal a_reg, b_reg: signed (15 downto 0); signal q_reg1, q_reg2: signed (15 downto 0); signal acc_out: signed (19 downto 0); begin process (clk, rst) begin if (rst = '1') then a_reg <= (others => '0'); b_reg <= (others => '0'); q <= (others => '0'); elsif (clk'event and clk = '1') then a_reg(0) <= a(0); a_reg(1) <= a(1); a_reg(2) <= a(2); a_reg(3) <= a(3); a_reg(4) <= a(4); a_reg(5) <= a(5); a_reg(6) <= a(6); a_reg(7) <= a(7); if (clk'event and clk = '0') then a_reg(8) <= a(8); a_reg(9) <= a(9); a_reg(10) <= a(10); a_reg(11) <= a(11); a_reg(12) <= a(12); a_reg(13) <= a(13); a_reg(14) <= a(14); a_reg(15) <= a(15); q_reg1 <= a_reg; end if; end if; end process; process (ena) begin if (ena = '1') then if (clk'event and clk = '1') then b_reg(0) <= b(0); b_reg(1) <= b(1); b_reg(2) <= b(2); b_reg(3) <= b(3); b_reg(4) <= b(4); b_reg(5) <= b(5); b_reg(6) <= b(6); b_reg(7) <= b(7); end if; if (clk'event and clk = '0') then b_reg(8) <= b(8); b_reg(9) <= b(9); b_reg(10) <= b(10); b_reg(11) <= b(11); b_reg(12) <= b(12); b_reg(13) <= b(13); b_reg(14) <= b(14); b_reg(15) <= b(15); q_reg2 <= b_reg; end if; acc_out <= q_reg1 + q_reg2; end if; end process; q <= acc_out; end rtl; --can anybody make it correct?? - Altera_Forum
--- Quote Start --- Suppose u r gonna pass out A (4 bits), define another vector for example B (2 bits), if clock'event and clock='1' then B(0) <= A(0); B(1) <= A(1); end if; if clock'event and clock='0' then B(0) <= A(2); B(1) <= A(3); end if; --- Quote End --- B is your real output - Altera_Forum
