15 years agoVHDL problem?
QUESTION: Develop a VHDL model for an accumulator that calculates the sum of a sequence of fixed-point numbers. Each input number is signed with 4 pre-binary-point and 12 post-binary-point bits....
15 years ago --- Quote Start --- B is your real output --- Quote End --- --this is my code but there are errors.. --the errors are Error (10344): VHDL expression error at acc.vhd(97): expression has 16 elements, but must have 20 elements Error: Can't elaborate top-level user hierarchy Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 2 warnings Error: Peak virtual memory: 183 megabytes Error: Processing ended: Wed Mar 30 08:42:58 2011 Error: Elapsed time: 00:00:01 Error: Total CPU time (on all processors): 00:00:01 Error: Quartus II Full Compilation was unsuccessful. 4 errors, 2 warnings library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity acc is port ( a: in signed (15 downto 0); b: in signed (15 downto 0); clk: in std_logic; ena: in std_logic; rst: in std_logic; q: out signed (19 downto 0) ) ; end acc; architecture rtl of acc is signal a_reg, b_reg: signed (15 downto 0); signal q_reg1, q_reg2: signed (15 downto 0); signal acc_out: signed (19 downto 0); begin process (clk, rst) begin if (rst = '1') then a_reg <= (others => '0'); b_reg <= (others => '0'); q <= (others => '0'); elsif (clk'event and clk = '1') then a_reg(0) <= a(0); a_reg(1) <= a(1); a_reg(2) <= a(2); a_reg(3) <= a(3); a_reg(4) <= a(4); a_reg(5) <= a(5); a_reg(6) <= a(6); a_reg(7) <= a(7); if (clk'event and clk = '0') then a_reg(8) <= a(8); a_reg(9) <= a(9); a_reg(10) <= a(10); a_reg(11) <= a(11); a_reg(12) <= a(12); a_reg(13) <= a(13); a_reg(14) <= a(14); a_reg(15) <= a(15); q_reg1 <= a_reg; end if; end if; end process; process (ena) begin if (ena = '1') then if (clk'event and clk = '1') then b_reg(0) <= b(0); b_reg(1) <= b(1); b_reg(2) <= b(2); b_reg(3) <= b(3); b_reg(4) <= b(4); b_reg(5) <= b(5); b_reg(6) <= b(6); b_reg(7) <= b(7); end if; if (clk'event and clk = '0') then b_reg(8) <= b(8); b_reg(9) <= b(9); b_reg(10) <= b(10); b_reg(11) <= b(11); b_reg(12) <= b(12); b_reg(13) <= b(13); b_reg(14) <= b(14); b_reg(15) <= b(15); q_reg2 <= b_reg; end if; acc_out <= q_reg1 + q_reg2; end if; end process; q <= acc_out; end rtl; --can anybody make it correct??
