15 years agoVHDL problem?
QUESTION: Develop a VHDL model for an accumulator that calculates the sum of a sequence of fixed-point numbers. Each input number is signed with 4 pre-binary-point and 12 post-binary-point bits....
15 years agoThe problem on this line
acc_out <= q_reg1 + q_reg2;is that acc_out is 20 bits and q_reg1 and q_reg2 are 16 bits. The result of the addition is 16 bits and it won't be resized automatically to 20 bits for you. Try something like that instead: acc_out <= resize(q_reg1,20) + resize(q_reg2,20);It is better to increase the size before performing the addition in case you need the 17th bit in the result and prevent an overflow. And by the way, b_reg(8) <= b(8);
b_reg(9) <= b(9);
b_reg(10) <= b(10);
b_reg(11) <= b(11);
b_reg(12) <= b(12);
b_reg(13) <= b(13);
b_reg(14) <= b(14);
b_reg(15) <= b(15);can be replaced by b_reg(15 downto 8) <= b(15 downto 8);
