14 years ago
VHDL DE2 board understanding Processes and Signals
So I wrote a program to turn on LEDS if SW, a switch, is '1' and off if '0'.
entity StateLCD is
	port(
		SW : in std_logic_vector(0 downto 0);
		LEDG : out std_logic_vector(7 downto 0);
		LEDR : out std_logic_vector(7 downto 0));
end StateLCD;
architecture StateLCD_Behaviour of StateLCD is
	SIGNAL LEDState: std_logic_vector(7 downto 0);
begin
	process(SW)
	begin
		if(SW = "1") THEN
			LEDState <= "11111111";
		else
			LEDState <= "00000000";
		end if;
		LEDG <= LEDState;
	end process;
end StateLCD_Behaviour;
It works, but shouldn't it only work if I used variables instead of signals? With signals, It seems like the LEDS should be turning off when SW is '1' and turning on at '0' since signals only update at the end of a process. So I would be getting the opposite of the output I want? Where as variables would update immediately. Thanks for any help.
    --- Quote Start ---
    Why does the synthesizer ignore the sensitivity list though? I don't quite get FvM explanation. Isn't what I'm doing hardware synthesis?
    --- Quote End ---
    It didn't actually explain this point, just stated a fact.
    Sensitivity lists in asynchronous processes are primarly intended to optimize the operation of a simulator that interprets the HDL code. As a side effect, they work as a kind of software edge detection. Apparently this gives room for a misunderstanding that sensitivity lists can be used for this purpose in hardware design.
    But the hardware way of evaluating asynchronous HDL code is basically different. The synthesis tools translates it to combinational gate circuits that don't care for state changes, just propagate the combined input data as they are, either if they change every clock cycle or stay for hours.
    In other words, to answer your question, you should consider how HDL code is mapped to hardware elements.
    --- Quote Start ---
    As FvM explained, this statement is only true with a simulator. A synthesizer will ignore the sensitivity list, and the best way to simulate what the synthesizer actually does is this code
    --- Quote End ---
    Ok. i think i might have misunderstood some things. thanks for clearing things up.
    --- Quote Start ---
    your sensitivity list only takes care of "SW", which means your process is only executed when there is any change in SW. signals are updated at the end of process, with your code it means the LEDG is assigned with the existing(previous) value.
    --- Quote End ---
    As FvM explained, this statement is only true with a simulator. A synthesizer will ignore the sensitivity list, and the best way to simulate what the synthesizer actually does is this code:
    process(SW,LEDState)
        begin
            if(SW = "1") THEN
            else
            end if;
            LEDG <= LEDState;
        end process;
    I've changed the sensitivity list to contain all the signals that are read by the process. If you simulate this, when you change the switch state the process will be executed a first time, update LEDState, then run a second time and update LEDG. Then you get the same behaviour between the simulation and the synthesized code.
    anyway, if you want to tie signals to outputs, you don't need to put them inside process
    --- Quote Start ---
    entity StateLCD is
        port(
    end StateLCD;
    begin
        process(SW)
        begin
            if(SW = "1") THEN
            else
            end if;
            LEDG <= LEDState;
        end process;
    --- Quote End ---
    Variable or signal will do since in both cases the assignment is fixed to same thing that depends only on switch state.
    Simple answer: Sensitivity lists are ignored in hardware synthesis.
    The bad with the present code is that a RTL simulation behaves different than the hardware.
