15 years agoVGA - horizantal sync pulse generation
hey,
I am trying to generate horizantal sync pulse with FSM. I write the next verilog code:
module horizantal_sync_pluse (
clock, //system clock
reset, //system reset
sync_pulse //horizantal sync pulse
//State machine parameters
parameter Scan_Line=1'b0;
parameter Gen_Sync_Pulse=1'b1;
input clock;
input reset;
output sync_pulse;
reg sync_pulse;
reg state;
reg counter;
always@(posedge clock, negedge reset)
begin
if (reset==0)
begin
state<=Gen_Sync_Pulse;
sync_pulse<=1'b0;
end begin
case (state)
Gen_Sync_Pulse:
if (counter==11'h00BC) begin //188
counter<=counter+1'b1;
sync_pulse<=1'b0;
end else
begin
state<=Scan_Line;
end
Scan_Line:
if (counter==11'h639) begin
sync_pulse<=1'b1;
state<=Scan_Line;
end else
begin
counter<=0;
end
default:
endcase
end
end
endmodule
after compilation I get Warning: Latch counter[0] has unsafe behavior Warning: Ports D and ENA on the latch are fed by the same signal sync_pulse~5 This warning is on each bit of the counter. why is it? how can I avoid it? Thanks7 Replies
Hey Kaz,
--- Quote Start --- I should add you to the list of My Gurus. So far only FvM and josyb managed to get there. --- Quote End --- You are too kind. I just happened to see localparam used in some of the Altera Verilog :) Cheers, Dave - Altera_Forum
Well Dave, I should add you to the list of My Gurus. So far only FvM and josyb managed to get there.
Regards - Altera_Forum
--- Quote Start --- I would like define parameter Scan_Line=1'b0; parameter Gen_Sync_Pulse=1'b1; How can I do it? --- Quote End --- Try localparam Scan_Line=1'b0; localparam Gen_Sync_Pulse=1'b1; Cheers, Dave - Altera_Forum
Well you can just not declare the unwanted parameters and use their assigned values directly in your code to replace their names.
Parameter is for helping code readability/updating only. At compile time they are replaced by its value. - Altera_Forum
Thanks. it happens to me sometimes, skip on this or that word. very diffecult to find asuch mistake by myself.
Thanks again - Altera_Forum
I haven't done verilog for years but I think you got simple error,
if reset == 0 begin ..... end else begin // you should put else here ....
