15 years agoTrue Dual Port Ram Synthesizes error with two clock signals
well i made a vhdl based, true dual port ram, and i wanted to use two separate clock input for each port, but QuatusII don't synthesizes it and generates the following error Error: Cannot synthesize dual-port RAM logic "ram" where 'ram' being : shared variable ram : memory_t; , well the problem is that when i use two clocks it gives this error, but when i use single clock, all goes well and i get no error. any thoughts over this problem? well the configuration of my system is, that i am using a Cyclone III - ep3c16q240 device, and first i want to test this RAM module alone, and further i will integrate it with my core, and then two different systems will be accessing this RAM with their specific clock. so this is the reason i need two clocks. will be looking forward for the support. thanks for your time. regards Ammar
