16 years agoTrue Dual Port Ram Synthesizes error with two clock signals
Hello, well i made a vhdl based, true dual port ram, and i wanted to use two separate clock input for each port, but QuatusII don't synthesizes it and generates the following error Error: ...
15 years agoIm guessing you have some unregistered read or write ports, and so you are causing timing problems as you move it around the FPGA, but these timing problems will be different for different parts of the FPGA because of different routing delays.
