16 years agoTrue Dual Port Ram Synthesizes error with two clock signals
Hello, well i made a vhdl based, true dual port ram, and i wanted to use two separate clock input for each port, but QuatusII don't synthesizes it and generates the following error Error: ...
16 years agoFvM has outlined the problem. Because you need chip selects you need to implement tri-state buffers on the IO. the CS signals control the tri-states and the we goes into the memory. The memory has no tri-state drivers of its own, so you have to write them yourself.
