16 years agoTrue Dual Port Ram Synthesizes error with two clock signals
Hello, well i made a vhdl based, true dual port ram, and i wanted to use two separate clock input for each port, but QuatusII don't synthesizes it and generates the following error Error: ...
15 years ago --- Quote Start --- could it be that the silicon of the FPGA is damaged?? or could it be because of the VCC/GND connections of the FPGA?? or some kind of interference inside FPGA?? --- Quote End --- My first instinct would be that it is none of these, and something to do with your tests and logic set up. If any of these were the case, I dont think anything would work. Please post some of the code you are using.
