15 years ago
system design using cyclone II
I am trying to implement a hardware system which uses current to compute distances. The incoming current is obtained from a sensor, and will be sampled and input into my FPGA. The ADC is 14bit, 250MSPS. A lock-in amplifier will be designed within the FPGA to extract the noise from a large amount of noise.
Now my problem is: My current signal is 154KHz. When I tried to build a PLL module using the ALT_PLL megafunction, the lowest required input frequency is 10MHz...
Now I am thinking of using two PLL modules, one to divide the 10MHz into 154Khz, if that is possible, the other to create its reference signal. Am I doing the right way? Is there a better way?
Also, I guess I need to build a buffer before ADC. but I dont know what type of buffer / where to get information about that. Could anyone help me? Thanks!
