15 years agosystem design using cyclone II
Hi, I am trying to implement a hardware system which uses current to compute distances. The incoming current is obtained from a sensor, and will be sampled and input into my FPGA. The ADC is 14...
15 years ago --- Quote Start --- Thanks dave, the web described blockgram works in a similar way as I described except that I am using the ALT_PLL to build my phase locked loop. but still. how can I compromise the difference between 154Khz and the lowest required ALT_PLL frequency 10MHz? --- Quote End --- You do not need a PLL operating at 154kHz. You need a complex-valued sinusoid operating at 154kHz. You get that using an ALT_PLL operating at 10MHz or more plus a Numerically Controller Oscillator (NCO) as provided by Altera; http://www.altera.com/literature/ug/ug_nco.pdf Re-read the SRS data sheet. They describe how their sinusoid is 24-bits. This means they have an NCO with 24-bits of output amplitude precision. I think the DSP blocks within the Cyclone II FPGAs can implement 9x9-bit, and 18x18-bit multiplications, so 18-bits of NCO precision would be easily handled. You need to work out your signal-to-noise requirements to determine how many bits you need in your design. Cheers, Dave
