15 years agosystem design using cyclone II
Hi, I am trying to implement a hardware system which uses current to compute distances. The incoming current is obtained from a sensor, and will be sampled and input into my FPGA. The ADC is 14...
15 years agoThanks dave, the web described blockgram works in a similar way as I described except that I am using the ALT_PLL to build my phase locked loop. but still. how can I compromise the difference between 154Khz and the lowest required ALT_PLL frequency 10MHz?
