14 years agoState A => State B multicycle path?
Is there a way to tell TimeQuest that all signals launched by State A and captured by State B are part of a multi-cycle path? My combinational path delay is too large so i'm adding a timer to delay my FSM state transition by one extra cycle. Previously, I have been using the SDC per below but I wonder if there is a way to tell TimeQuest that any signals travelling between the launch and latch FF's are multicycle?
set_multicycle_path -setup -end -from [get_keepers {main_controller:main_controller_inst|reg_rx_regs_offset[*]}] -to [get_keepers {tx_tlp_buffer:tx_tlp_buffer_inst|mem[*][*]}] 2 set_multicycle_path -hold -end -from [get_keepers {main_controller:main_controller_inst|reg_rx_regs_offset[*]}] -to [get_keepers {tx_tlp_buffer:tx_tlp_buffer_inst|mem[*][*]}] 2 Thanks23 Replies
--- Quote Start --- But if the output of Latch_FF isn't considered to be 'valid' until T2 then the Downstream_FF won't be 'using' this value until T3 at which point it will be a solid '1' or '0'. --- Quote End --- It is very unsafe design to violate register timing and then wait until it recovers. A register may not end up in the right state if it is violated. This practice is unavoidable across clk domain transfers (but two synchroniser stages are needed in this case) - Altera_Forum
--- Quote Start --- So, after T2 clock edge, Latch_FF will (most likely) have a correct value. But what Downstream_FF will be latching at the T2 clock edge is based on what Latch_FF had prior to the clock edge -- a bad value. --- Quote End --- But if the output of Latch_FF isn't considered to be 'valid' until T2 then the Downstream_FF won't be 'using' this value until T3 at which point it will be a solid '1' or '0'. ? I think I'd rather find a work around to this but think that what the OP says is true (with the caveat about registering the correct output at T2). Nial. - Altera_Forum
--- Quote Start --- My point is that the statement in bold doesn't apply. The reason is that downstream combinational logic will block the metastable signal from reaching the next register. Only at T2 will the combination logic let the Latch_FF.Q signal through to the next register. At T2 the Latch_FF.Q will not be metastable. --- Quote End --- I think you got confused on something basic. This may be simpler to understand if, instead we assume Latch_FF will go metastable at T1, we simply assume the delay is so long that it totally overshoots the tSU/tH window at T1 and Latch_FF simply latches the old value. At the T2 clock edge, two things happen at the same time: - Latch_FF latches the value at it's input prior to the clock edge - Downstream_FF latches the value at it's input prior to the clock edge. So, after T2 clock edge, Latch_FF will (most likely) have a correct value. But what Downstream_FF will be latching at the T2 clock edge is based on what Latch_FF had prior to the clock edge -- a bad value. - Altera_Forum
--- Quote Start --- Once again, I agree. The metastability may settle out on the next clock edge, but in the mean time, it may cause other registers down stream to go metastable. --- Quote End --- As explained, this cannot happen in my design since combinational logic will block the metastable signal from reaching the target register at T1. --- Quote Start --- In addition to that, it also creates noise in a circuit which can cause crosstalk to other nearby traces. --- Quote End --- Crosstalk inside the FPGA? This is a new concept I have not come across before. If FPGAs were susceptible to crosstalk internally, how can signals belonging to different clock domains be mixed inside the FPGA. This would surely cause internal signal paths belonging to one clock domain to switch randomly with regards to other signals belonging to other clock domains, causing havoc? - Altera_Forum
--- Quote Start --- If a FF hasn't resolved to a stable state by the next clock edge, it's normal timing characteristics (tSU, tH, tCO) may not apply. Hence, it's not 100% sure that it will behave normally. --- Quote End --- Where can i find documentation to back up this statement? - Altera_Forum
--- Quote Start --- This is what it looks like to me: T0: Launch_FF latches a new value T1: Latch_FF latches a bad value, as the previous transition from Launch_FF hasn't completely propagated yet T2: Latch_FF latches a good value as the previous transition finally had time to propagate; downstream_ff latches a bad value, from the bad value launch_ff had before.T3: Downstream_FF finally latches a good value. --- Quote End --- My point is that the statement in bold doesn't apply. The reason is that downstream combinational logic will block the metastable signal from reaching the next register. Only at T2 will the combination logic let the Latch_FF.Q signal through to the next register. At T2 the Latch_FF.Q will not be metastable. - Altera_Forum
I think we'll both agree that trying to rely on behavior that involves metastability is dialing Murphy's number.
--- Quote Start --- If a FF hasn't resolved to a stable state by the next clock edge, it's normal timing characteristics (tSU, tH, tCO) may not apply. Hence, it's not 100% sure that it will behave normally. --- Quote End --- Once again, I agree. The metastability may settle out on the next clock edge, but in the mean time, it may cause other registers down stream to go metastable. In addition to that, it also creates noise in a circuit which can cause crosstalk to other nearby traces. As I said before, set your multicycle hold to 0, then if you meet timing it won't go metastable. If you can't meet the hold time, then add a clock enable. - Altera_Forum
Hence, it's not 100% sure that it will behave normally. - Altera_Forum
--- Quote Start --- I'm quite clear (at least in my mind): The multi-cycle path simply tells TimeQuest that Tsu for Latch_FF is not met at T1 but at T2 it is. The output of Latch_FF is irrelevant at all times except at T2. Therefore, the source signal is launched by Launch_FF.Q at T0, captured by Latch_FF.D at T1 (Latch_FF.Q possible metastable but this is don't-care since Latch_FF.Q is only used at T2) and finally captured by Latch_FF.D at T2. Downstream logic will ignore the output from Latch_FF.Q until t == T2. --- Quote End --- This doesn't look good.. This is what it looks like to me: T0: Launch_FF latches a new value T1: Latch_FF latches a bad value, as the previous transition from Launch_FF hasn't completely propagated yet T2: Latch_FF latches a good value as the previous transition finally had time to propagate; downstream_FF latches a bad value, from the bad value Launch_FF had before. T3: Downstream_FF finally latches a good value. Or making it short. An exception like "set_multycycle_path -from [launch_FF] -to [latch_FF]" concerns the path between launch_FF.Q and latch_FF.D. If you're making considerations for stuff downstream of latch_FF or upstream launch_FF, and coming to an exception that like, then you're getting it wrong.
