14 years agoState A => State B multicycle path?
Is there a way to tell TimeQuest that all signals launched by State A and captured by State B are part of a multi-cycle path? My combinational path delay is too large so i'm adding a timer to delay m...
14 years ago --- Quote Start --- I'm quite clear (at least in my mind): The multi-cycle path simply tells TimeQuest that Tsu for Latch_FF is not met at T1 but at T2 it is. The output of Latch_FF is irrelevant at all times except at T2. Therefore, the source signal is launched by Launch_FF.Q at T0, captured by Latch_FF.D at T1 (Latch_FF.Q possible metastable but this is don't-care since Latch_FF.Q is only used at T2) and finally captured by Latch_FF.D at T2. Downstream logic will ignore the output from Latch_FF.Q until t == T2. --- Quote End --- This doesn't look good.. This is what it looks like to me: T0: Launch_FF latches a new value T1: Latch_FF latches a bad value, as the previous transition from Launch_FF hasn't completely propagated yet T2: Latch_FF latches a good value as the previous transition finally had time to propagate; downstream_FF latches a bad value, from the bad value Launch_FF had before. T3: Downstream_FF finally latches a good value. Or making it short. An exception like "set_multycycle_path -from [launch_FF] -to [latch_FF]" concerns the path between launch_FF.Q and latch_FF.D. If you're making considerations for stuff downstream of latch_FF or upstream launch_FF, and coming to an exception that like, then you're getting it wrong.
