15 years agoSopc Help
hi again,
I'm using a SDRAM controller in SOPC. but things are not working right. Failing paths, buffer of templates are getting full , ... I'm using master write and master read MM-templates from the site. I connected 3 read's and 5 writes to the SDRAM Controller. What else do i need to do? Can anyone plz help me with a good tutorial or a easy reference design ? Regards Edit: For any help i added a pic of the sopc14 Replies
--- Quote Start --- AFAIK sopc builder generates the sdc file by default, together with the .qip file which contains the hdl file references. At least this is true for the Quartus version 9.0sp2 I use. Did you select TimeQuest as time analyzer? --- Quote End --- I only see the SDC wich i made. I don't have one generated by SOPC builder. I use version 8.0. I'll try shifting the SDRAM CLK but I probably need to reduce the speed of the avalon bus with all those components on it. I was running it at 144MHz. - Altera_Forum
--- Quote Start --- You have to enable the settings for that? Cauze i can't find it in the main directory. --- Quote End --- AFAIK sopc builder generates the sdc file by default, together with the .qip file which contains the hdl file references. At least this is true for the Quartus version 9.0sp2 I use. Did you select TimeQuest as time analyzer? Regarding the sdram clock phase, I remember it must be calculated somehow like this (although I'm not completely sure): - pre-compile the project with 0 phase shift - search the PLL offset in the timing analysis report - search the sdram clock combinatorial delay from pll output to clock pin - the sdram clock phase lead must be set that the sum of pll offset and combinatorial delay is a bit longer than the sdram setup time - recompile the Quartus project I use the same SDRAM as yours and EP3C40: with Fclk=100MHz I set dram clk phase = -27degrees = -0.75ns. As a rule of thumb you can also try -0.75ns which for your 148MHz would mean a phase lead of 40deg. Regards - Altera_Forum
--- Quote Start --- Sopc builder should have generated automatically a .sdc file for your system. You must include it in your Quartus project. --- Quote End --- You have to enable the settings for that? Cauze i can't find it in the main directory. --- Quote Start --- Also make sure your checked the "Timing driven synthesis" in Analysis&Synthesis settings and follow the other guidelines reported by timing optimization advisor. --- Quote End --- I did. --- Quote Start --- Final note: probably this is not your current problem, but usually you must drive the sdram clock pin with a phase lead relative to clock used by sopc system. --- Quote End --- Probably you need to apply that in the sdc aswell. How? - Altera_Forum
--- Quote Start --- do i need a diffrent ip.sdc for the sopc? Here is my SDC-File for main design: --- Quote End --- Sopc builder should have generated automatically a .sdc file for your system. You must include it in your Quartus project. Also make sure your checked the "Timing driven synthesis" in Analysis&Synthesis settings and follow the other guidelines reported by timing optimization advisor. If all this fails maybe the 144MHz frequency is really too high for your device. Final note: probably this is not your current problem, but usually you must drive the sdram clock pin with a phase lead relative to clock used by sopc system. - Altera_Forum
Did some tests,
With 1 write master MM to SDRAM controller fmax 132MHz I Added one -> 2 Write masters to SDRAM controller fmax 115MHz - Altera_Forum
--- Quote Start --- Either you are using a too high clk frequency or you have a bad create_clock command in the TimeQuest sdc file. --- Quote End --- Fmax is about 132MHz but that is when i remove all the others VHDL and only generate a Sopc with one Write master and one SDRAM controller. The second option could be a problem. I don't have much experience with SDC file or asserting constraints. I followed TimeQuest User Guide by Ryan Scoville. do i need a diffrent ip.sdc for the sopc? Here is my SDC-File for main design:
FPGA_CLK_1 and _2 are 48MHz input clk's that go straight to a PLL each. They generate a freq of 48MHz and 144MHz. The generated CLK 144MHz i use for the SOPC gives failing paths (setup) --- Quote Start --- Some suggestions: - If the SDRAM controller you are using does not support burst then don't enable bursting in the masters. --- Quote End --- It does. It supports a burst of 1,2,4,8. I set every burst on 8. --- Quote Start --- - Increase the arbitration share of each master to allow multiple back to back transfers from each master to access the SDRAM - Increase the data width of the master to match your memory controller width --- Quote End --- I'll try them, but i was trying to avoid the last suggestion because then i need to make the code a little more complex. If i increase arbitration shares, that will have no affect on the slack. or am i wrong? Aditional info: FPGA : Cyclone III EP3C10F256C8N SDRAM : IS42S16400B If more info is required plz ask. Thx for the reply's.# **************************************************************# Time Information# ************************************************************** set_time_format -unit ns -decimal_places 3 # **************************************************************# Create Clock# ************************************************************** create_clock -name {FPGA_CLK1} -period 20.833 -waveform { 0.000 10.416 } create_clock -name {FPGA_CLK2} -period 20.833 -waveform { 0.000 10.416 } create_clock -name {PIX_CLK} -period 20.833 -waveform { 0.000 10.416 } # **************************************************************# Create Generated Clock# ************************************************************** derive_pll_clocks # **************************************************************# Set Clock Latency# ************************************************************** # **************************************************************# Set Clock Uncertainty# ************************************************************** derive_clock_uncertainty - Altera_Forum
Some suggestions:
- If the SDRAM controller you are using does not support burst then don't enable bursting in the masters. - Increase the arbitration share of each master to allow multiple back to back transfers from each master to access the SDRAM - Increase the data width of the master to match your memory controller width - Altera_Forum
--- Quote Start --- Setup paths within the SOPC with slack of -1.953 Lots of them. --- Quote End --- Either you are using a too high clk frequency or you have a bad create_clock command in the TimeQuest sdc file. - Altera_Forum
Redesigned the SOPC for 1 camera -> 1 Write MM-Template
Spec of MM Template : - FIFO = 256 - Burst Enabled and 8 --- Quote Start --- where are your failing paths? --- Quote End --- --- Quote Start --- Do you have the same problem with less masters in your SOPC design? --- Quote End --- Setup paths within the SOPC with slack of -1.953 Lots of them. - Altera_Forum
Another Question:
If u use the write - MM Master like follows: (FIFO is filled by camera at 48MHz : 1 byte every clk) (SDRAM works on clk of 144MHz) U send : GO, Adress = 0x000000000 , Number of Bytes = 640 decimal What will happen? I can think of some things. - FIFO will run empty and the component will have no data to transmit. But will the write controller freeze?
