15 years agoSopc Help
hi again, I'm using a SDRAM controller in SOPC. but things are not working right. Failing paths, buffer of templates are getting full , ... I'm using master write and master read ...
15 years ago --- Quote Start --- Setup paths within the SOPC with slack of -1.953 Lots of them. --- Quote End --- Either you are using a too high clk frequency or you have a bad create_clock command in the TimeQuest sdc file.
