15 years agoSopc Help
hi again, I'm using a SDRAM controller in SOPC. but things are not working right. Failing paths, buffer of templates are getting full , ... I'm using master write and master read ...
15 years agoAnother Question:
If u use the write - MM Master like follows: (FIFO is filled by camera at 48MHz : 1 byte every clk) (SDRAM works on clk of 144MHz) U send : GO, Adress = 0x000000000 , Number of Bytes = 640 decimal What will happen? I can think of some things. - FIFO will run empty and the component will have no data to transmit. But will the write controller freeze?
