15 years agoSopc Help
hi again, I'm using a SDRAM controller in SOPC. but things are not working right. Failing paths, buffer of templates are getting full , ... I'm using master write and master read ...
15 years agoRedesigned the SOPC for 1 camera -> 1 Write MM-Template
Spec of MM Template : - FIFO = 256 - Burst Enabled and 8 --- Quote Start --- where are your failing paths? --- Quote End --- --- Quote Start --- Do you have the same problem with less masters in your SOPC design? --- Quote End --- Setup paths within the SOPC with slack of -1.953 Lots of them.
