15 years agoSopc Help
hi again, I'm using a SDRAM controller in SOPC. but things are not working right. Failing paths, buffer of templates are getting full , ... I'm using master write and master read ...
15 years agoSome suggestions:
- If the SDRAM controller you are using does not support burst then don't enable bursting in the masters. - Increase the arbitration share of each master to allow multiple back to back transfers from each master to access the SDRAM - Increase the data width of the master to match your memory controller width
