15 years agoSopc Help
hi again, I'm using a SDRAM controller in SOPC. but things are not working right. Failing paths, buffer of templates are getting full , ... I'm using master write and master read ...
15 years agoI'll test that.
But I also have a question: Some of my write masters get a buffer full. Fifo dept is 258 and there should be enough of time to write them to the SDRAM. If i assing a GO to 2 components at the same time the arbiter can handle that ... right or not?
