15 years agoSopc Help
hi again, I'm using a SDRAM controller in SOPC. but things are not working right. Failing paths, buffer of templates are getting full , ... I'm using master write and master read ...
15 years agowhere are your failing paths? Adding the pipelines should already help, but in some cases it can be the design inside your component that can be the problem.
Do you have the same problem with less masters in your SOPC design?
