15 years ago
simple verilog question...
hi there!
im trying to determine the root cause of an error i keep getting.
Basically I'm trying to convert a 2's complement value, lets say binary X to
decimal Y (i do this by multiplying it with a constant [i.e. 625]).
1) so I do this, and it works perfectly.
assign X_n = ~X - 1;
always@(posedge CLK)
begin
Y = X_n * 625;
end
2)BUT I can't do this:
begin
Y = (~X - 1) * 625;
end
I get a weird number with the second case. Does anyone know why??
Thanks in advance! This question has been bugging me for some time.
    I already mentioned, that the intermediate result bitwidth causes a different result. Thus I had been asking for the definition of data types used in the original example, but we face considerably different Verilog text in each post. Consequently, the results are different for each example. I miss a clear question now.
    I had a quick go at your code and reproduced your finding.
    Your design is not constrained in the sense of data bitwidth into and out of operations.
    in the first expression, your multiplier gives correct output.
    in the second expression, your multiplier gives correct output for 11 bits only, other bits are set by compiler to wrong values, apparently considered as don't care.
    I also notice that you are keeping positive input values but forcing negative input values to positive. Is that what you really intend to do?
    I suggest you declare signed types for inputs and outputs and constrain the width of all your results at all stages.
    Here is the code in question...
    --- Quote Start ---
    input [11:0] input_temp;
    output [7:0] actual_temp; //actual temperature
    reg [21:0] temp;
    wire [10:0] input_temp_n;
    assign actual_temp = temp/10000;
    assign input_temp_n = (~input_temp[10:0]) + 1;
    always@(posedge iCLK)
    begin
    if(!input_temp[11])
    begin
    temp = (input_temp[10:0] * 625);
    end
    else
    begin
    temp = (input_temp_n * 625);
    //offending code
    //temp = ((~input_temp[10:0] + 1) * 625);
    end
    end
    --- Quote End ---
    BTW sorry for lack of indentation. i dont know why but these forums kill my indentation. anyone know how to fix?
    Im also think there is somthing involved in your data types.
    Can you show a snipset of the code with the data types and width included?
    --- Quote Start ---
    thanks for the response Kaz!
    Let me break it down a bit more however. The two expressions are actually the same (logically). But the outcome is different. In other words,
    assign X_n = ~X;
    begin
    Y = X_n * 625;
    end
    DOES NOT equal the below equation
    begin
    Y = ~X * 625;
    end
    --- Quote End ---
    I deleted my initial post because it turned out unrelated !!
    you started presenting your problem as 2's complement conversion ...But the issue is actually about two apparently equivalent expressions having two results.
    What I supposed first was this:
    unsigned to signed: invert bits then add 1
    signed to unsigned :subtract 1 then invert bits = invert bits then add 1
    clearly irrelevant but the order of operations is important.
    Regarding your issue, I suggest you post your entire code.
    Seriously, we can't know what's the expectable or correct result without knowing the involved data types. Bit width of signals is most likely the key to understand why the results are different. When assinging X_n = ~X - 1, the result is truncated to a specified width. In Y = (~X - 1) * 625, the intermediate result gets a default width of 32 bit.
    assign X_n = ~X;
    begin
    Y = X_n * 625;
    end
    begin
    Y = ~X * 625;
    end
