15 years agosimple verilog question...
hi there! im trying to determine the root cause of an error i keep getting. Basically I'm trying to convert a 2's complement value, lets say binary X to decimal Y (i do this by multiplying...
15 years ago --- Quote Start --- thanks for the response Kaz! Let me break it down a bit more however. The two expressions are actually the same (logically). But the outcome is different. In other words, assign X_n = ~X; always@(posedge CLK) begin Y = X_n * 625; end DOES NOT equal the below equation always@(posedge CLK) begin Y = ~X * 625; end --- Quote End --- I deleted my initial post because it turned out unrelated !! you started presenting your problem as 2's complement conversion ...But the issue is actually about two apparently equivalent expressions having two results. What I supposed first was this: unsigned to signed: invert bits then add 1 signed to unsigned :subtract 1 then invert bits = invert bits then add 1 clearly irrelevant but the order of operations is important. Regarding your issue, I suggest you post your entire code.
