Random single hold violations on Arria V design that doesn't push timing or util. ???
Hi - I have a design that uses about 20% of the FPGA Fabric on an ArriaVSoc. I've added my own logic to the GHRD. It doesn't push timing (my logic is 100MHz or less), or utilization (see above, even memory utilization is < 30%), but about 50% of the builds fail with a single hold violation. About 1/3 the time it's on altera_reserved_tck, and the other 2/3 it's in a random place in my portion of the design (but never in the same place twice). Messing with the seed eventually fixes it (until next time), but it takes about an hour to build, so re-building is a pain I have Placement and routing effort turned up (4.0 and max). The thing that in all cases it looks like a buffer would have fixed it. is this a bug? Is there a fix? Is there a workaround? I'm running the latest Quartus 13 on CentOS.
Thanks! /j
