12 years agoRandom single hold violations on Arria V design that doesn't push timing or util. ???
Hi - I have a design that uses about 20% of the FPGA Fabric on an ArriaVSoc. I've added my own logic to the GHRD. It doesn't push timing (my logic is 100MHz or less), or utilization (see above, eve...
12 years agoThanks Tricky. My design contains
a) the ArriaV SoC Golden Reference Design b) some new logic I generated c) a block I designed last year that has been built many dozens of times and ships in a customers' product.(albeit on a Stratix IV) I get hold violations, consistently, very deep in block c) in a simple multi-bit shift register on a single clock domain. (so very little logic between registers) Quartus just appears to be unwilling (or unable?) to insert delay between two sequential registers. If remove a significant amount of logic from the total design (like 1/2 of b) ) the issues go away. it's just weird.... I know how to fix setup vios, and cross-clock-domain stuff, but not hold vios deep in a single clock domain - except by adding buffers. /j
