12 years agoRandom single hold violations on Arria V design that doesn't push timing or util. ???
Hi - I have a design that uses about 20% of the FPGA Fabric on an ArriaVSoc. I've added my own logic to the GHRD. It doesn't push timing (my logic is 100MHz or less), or utilization (see above, eve...
12 years agoACTUALLY - I think I found the common thread. these are all DSP-block to DSP-block paths. In the original design, the customer was short on DSP blocks so I forced it to build gate multipliers, I removed that constraint for this revision. Trying it now with the constraint back in place.
Can't Quartus resolve hold vios between dsp blocks? /j
