12 years agoRandom single hold violations on Arria V design that doesn't push timing or util. ???
Hi - I have a design that uses about 20% of the FPGA Fabric on an ArriaVSoc. I've added my own logic to the GHRD. It doesn't push timing (my logic is 100MHz or less), or utilization (see above, eve...
12 years agoCheck the start and end points - do they make sense?
In a previous version of Quartus I have seen it merge registers in two different entities, creating violations in two bits of logic that should have no relation to each other. I had to specific that auto-shift register recognition was turned off for these two entites - it broke the connection and removed the timing violations.
