8 years agoNo logic elements although I have an output
Hello
Please guide me why I don't see any logic element for the current code : LIBRARY ieee; USE ieee.std_logic_1164.all; Use ieee.numeric_std.all; USE work.my_data_types.all; -- to define array of input ( package ) ENTITY test IS PORT ( clk: in std_logic; OutResult: out signed(9 downto 0)); end test; Architecture behave of test is Signal Im : Array2D:=(("0010000111","0001111110","0001001101","0000000000","0000000000"), ("0001001111","0010000100","0000101100","0000011011","0000000000"), ("0001011101","0010000100","0000100111","0000101001","0000000000"), ("0001011101","0010000100","0000100111","0000101001","0000000000"), ("0000000000","0000000000","0000000000","0000000000","0000000000")); signal Bufftemp:Array2D; signal Buffsig:signed(9 DOWNTO 0); begin Process (clk) variable i,j:integer range 0 to 7:=0; begin if (clk' event and clk='1') then for j in 0 to 1 loop for i in 0 to 1 loop Bufftemp(2*j,2*i+1)<= Im(2*j,2*i+1) - 5; end loop; end loop; end if; Buffsig<=Bufftemp(i,j); end process; OutResult<=Buffsig; end behave;26 Replies
You cant "get more time"
Remmeber that all processes run simultaneously. All assignments happen in parrellel I suggest reviewing your VHDL training materials. This is NOT like software programming. - Altera_Forum
Is it the pipeline I thought I could make!
I will check it out , I am really thankful to you Mr. And will review my codes. For Modelsim I will try it out and give you feed back. Your efforts are highly appreciated. - Altera_Forum
You will benefit from Drawing the circuit you expect before writing any code. When writing VHDL you need to understand the circuit you're creating - it is VHSIC Hardware description language. So you need to know what hardware you are describing.
--- Quote Start --- You will benefit from Drawing the circuit you expect before writing any code. When writing VHDL you need to understand the circuit you're creating - it is VHSIC Hardware description language. So you need to know what hardware you are describing. --- Quote End --- Great remark ... I will work by it . Many thanks. - Altera_Forum
--- Quote Start --- You cant "get more time" Remmeber that all processes run simultaneously. All assignments happen in parrellel I suggest reviewing your VHDL training materials. This is NOT like software programming. --- Quote End --- The number of logic elements are enormous ! is that because I have the entire image inside logic elements and I didn't utilize any memory ? - Altera_Forum
Without the code, I cannot tell. I assume your code is not what you already posted?
Storing an image in logic will be very expensive. You really should use ram. - Altera_Forum
--- Quote Start --- The number of logic elements are enormous ! is that because I have the entire image inside logic elements and I didn't utilize any memory ? --- Quote End --- Quartus can infer internal hardware memory (RAM or ROM) from HDL code automatically without an explicit memory block instantiation. But the implemented memory function must be compatible with the properties of FPGA memory blocks. E.g. you can't access more than one respectively two (using the dual port feature) memory addresses within a clock cycle. Your code in post# 9 is obviously not compatible with the memory inference rules. Using the Quartus RAM and ROM templates assures that you're designing valid memory code. - Altera_Forum
--- Quote Start --- Without the code, I cannot tell. I assume your code is not what you already posted? Storing an image in logic will be very expensive. You really should use ram. --- Quote End --- I changed the code since as you advice me I can not fill same memory in two processes even if I am filling different locations. But I got the bigger problem of logic element localization. The new code is below , One process consumes 109 logic element! Decompose array is an 8*8 array LIBRARY ieee; USE ieee.std_logic_1164.all; Use ieee.numeric_std.all; USE work.my_data_types.all; -- to define array of input ( package ) ENTITY NewD IS PORT ( clk: in std_logic; bufftest:out signed(9 DOWNTO 0)); end NewD; Architecture behave of NewD is SIGNAL Im: Array2D:=(("0010000111","0001111110","0001001101","0001011011","0001101001","0001101011","0001101001","0001100111","0001101000","0001100000","0001110011","0010000100","0010001111","0010000000","0001100000","0001000100","0000000000"), ("0010000111","0001111010","0001001010","0001011001","0001100110","0001101000","0001110010","0010000001","0001101111","0001011100","0001101001","0010000011","0001111010","0010011000","0001000111","0000010010","0000000000"), ("0001100011","0001110111","0001000110","0001010110","0001011111","0001100001","0001110100","0010011100","0010101100","0001101111","0001100011","0001101001","0001110100","0001100000","0000011001","0000110101","0000000000"), ("0001001100","0001111000","0001000101","0001011000","0001011011","0001100011","0001111000","0010011111","0010110010","0010101111","0001111000","0001010000","0010000001","0000101100","0000100100","0001111100","0000000000"), ("0001010010","0001111100","0001000101","0001100000","0001100000","0001100110","0010000101","0010011000","0010011111","0010100100","0010011111","0010100011","0010100111","0000100101","0001011111","0010001000","0000000000"), ("0001010101","0010000000","0001000100","0001100100","0001110110","0001101001","0001101100","0001011111","0001100000","0010010011","0010101001","0010011100","0001010110","0000110011","0010000110","0010000011","0000000000"), ("0001010110","0001111111","0001000100","0001011001","0001111011","0001010111","0000110001","0000101001","0001110100","0010100100","0010000101","0001010000","0000011011","0001011101","0010001101","0010000011","0000000000"), ("0001010010","0010000000","0001001000","0001011011","0001011100","0000101010","0000100001","0001101100","0001111100","0010011100","0010000010","0000101110","0000100111","0001111101","0010000100","0001111010","0000000000"), ("0001001011","0010000010","0001001110","0001010111","0000111001","0000100100","0001001000","0001111001","0001100001","0010000011","0001010001","0000110000","0001000100","0010000100","0001111100","0010000100","0000000000"), ("0000111010","0010000000","0001010011","0001000000","0000101001","0000111000","0001010000","0001101110","0010001001","0010000011","0001100101","0000110001","0001100011","0001111110","0010000110","0010110000","0000000000"), ("0000111010","0010000100","0001001010","0000111000","0001000100","0001001110","0000101101","0001100111","0001110111","0010000001","0001000001","0000110111","0001111011","0001111000","0010011111","0010111101","0000000000"), ("0000110001","0010001000","0001000001","0000111001","0001011111","0000110010","0000011101","0001001001","0001110011","0001101010","0000011100","0001000011","0001111111","0001110110","0010101110","0010110001","0000000000"), ("0001000011","0010000010","0000110110","0000110001","0001010010","0000110011","0000011010","0000111100","0001110100","0010001101","0001100000","0001000101","0001101101","0001101000","0010100001","0001001100","0000000000"), ("0001010011","0010000010","0000101101","0000100000","0001000000","0001000111","0000100100","0001010001","0001110011","0010001100","0010110010","0001101011","0001110010","0010001110","0001111110","0001000100","0000000000"), ("0001001111","0010000100","0000101100","0000011011","0000110101","0000101011","0000110010","0001100010","0001110011","0001111100","0010101001","0010001111","0001001111","0010001001","0001010100","0000111110","0000000000"), ("0001011101","0010000100","0000100111","0000101001","0000110011","0000101000","0001001111","0001101101","0001110110","0001111000","0010010101","0010011111","0001001110","0001010111","0000111110","0000110110","0000000000"), ("0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000")); signal DRP0sig:DecompArray; begin ------ RP0 RP0: Process (clk) variable i:integer range -1 to 8:=-1; variable j:integer range 0 to 7:=0; variable cntrr:integer range 0 to 256; -- THIS COUNTER I made to take one output each clock cycle begin if (clk' event and clk='1') then i:=i+1; if i>7 then i:=0; j:=j+1; if j=8 then j:=0; end if; end if; DRP0sig(j,i)<= Im(2*j,2*i+1) - 5;-- to modify the image value end if; bufftest<=DRP0sig(cntrr,0); --show the first column of output end process; end behave; - Altera_Forum
--- Quote Start --- Quartus can infer internal hardware memory (RAM or ROM) from HDL code automatically without an explicit memory block instantiation. But the implemented memory function must be compatible with the properties of FPGA memory blocks. E.g. you can't access more than one respectively two (using the dual port feature) memory addresses within a clock cycle. Your code in post# 9 is obviously not compatible with the memory inference rules. Using the Quartus RAM and ROM templates assures that you're designing valid memory code. --- Quote End --- For no. 9 I will try to read them in buffer one by one. As I think , my code above consumes one each time. I tried to use the memory initialization written below with the code , but I still get the large number of logic element along with the memory. But I don't know if the large number because the input is not a RAM or because I am trying to output all the values mistakenly ? BTW I am reading and revising your notes many times even after I reply to you. This is the initialization M4K I used , if you have any notes to advice me .. TYPE memory IS ARRAY (0 to 1023) OF STD_LOGIC_VECTOR(7 DOWNTO 0); SIGNAL myram: memory; ATTRIBUTE ram_init_file: STRING; ATTRIBUTE ramstyle: STRING; ATTRIBUTE ramstyle OF myram: SIGNAL IS "M4K"; - Altera_Forum
Initially, you may do better using the mega wizard to generate the ram, then you know for sure that a ram will be used. Infered ram has to match the correct behavioural template to be correctly inferred, otherwise logic will be inferred.
Review this document for coding styles: https://people.ece.cornell.edu/land/courses/ece5760/de1_soc/hdl_style_qts_qii51007.pdf
