8 years agoNo logic elements although I have an output
Hello Please guide me why I don't see any logic element for the current code : LIBRARY ieee; USE ieee.std_logic_1164.all; Use ieee.numeric_std.all; USE work.my_data_types.all; -- to def...
8 years agoInitially, you may do better using the mega wizard to generate the ram, then you know for sure that a ram will be used. Infered ram has to match the correct behavioural template to be correctly inferred, otherwise logic will be inferred.
Review this document for coding styles: https://people.ece.cornell.edu/land/courses/ece5760/de1_soc/hdl_style_qts_qii51007.pdf
