8 port 10/25G ethernet interface in Stratix 10
We have custom board made with Stratix 10 1ST085EN2F43I2LG. The board has 8 SFP28 ports the needs to talk to 10/25G ethernet devices. This board is used to test the connected devices by sending a fixed Ethernet packets and analyse the received Ethernet packets.
The SFP ports needs to be selectable between 10G and 25G and enable/Disable RS-FEC. Also need the MAC statistics registers and PTP timestamping.
We could see two different IP cores available for this in the IP catalogue,
- 25G Ethernet Stratix 10 IP, and
- Ethernet Stratix 10 E-Tile Hard IP.
Which one is the right IP for this requirement.
- Sajeev_antony
not able to attach archived project or fitter report file
- paveetirrasrie_Altera
Hello Sanjeev,
We will continue to monitor this post for the next 5 days. If there are no further inquiries during this period, I will step back and allow the community to assist with any future follow-up questions.
Altera Technical Support
- Sajeev_antony
o_tx_serial_n Incomplete set of assignments. Missing I/O standard, drive strength and slew rate assignments on output pin 1
i_rx_serial_n Missing I/O standard 2
- Sajeev_antony
The ip generates seperat P and N signals of the serial TX and RX lanes as,
o_tx_serial, o_tx_serial_n, i_rx_serial, i_rx_serial_n
I gave pin location assignments to these pins.
But Quartus 2026.1 says
Critical Warning(25196): A programming file will not be generated because the assembler identified user pins missing pin location assignments. Refer to the I/O Assignment Warnings table in the fitter report for a list of unassigned pins. You can assign these pins in the Pin Planner tool and recompile to allow programming file generation to pass.
In the fitter list it lists o_tx_serial_n and i_rx_serial_n
How to give pin assignment to these dedicates transiver lines.
Can you try to just assign o_tx_serial and i_rx_serial and run the compilation, let the Quartus to auto assign the N signals.
Kindly do let me know if that works.
Pavee
- Sajeev_antony
Is there any simple design that i can use to test the ports.
Just want to send a fixed ethernet packet from one port and receive the same at another port and check the received data.
I have set the reference clock to 156.25MHz.
Also what is the procedure to switch between 10G and 25G rates.
Testing with a Fixed Ethernet Packet (Port-to-Port / Loopback)
The quickest path is the E-Tile Hard IP for Ethernet hardware design example, which includes a built-in packet generator and checker. The hardware design example includes the E-Tile Hard IP for Ethernet IP core plus a PCS packet generator and checker that coordinates IP core programming, packet generation, and packet verification. 100GE PCS with Optional RS-FEC Hardware Design Example Components
After compiling and programming the device via JTAG, you drive it through the Quartus Prime System Console using a Tcl script. The key commands you'll use are:
start_pkt_gen — starts the packet generator; stop_pkt_gen — stops it. 100GE MAC+PCS with Optional (528,514) RS-FEC or (544,514) RS-FEC and Adaptation Flow Hardware Design Example
chkphy_status — displays clock frequencies and PHY lock status; chkmac_stats — displays MAC statistics counter values; clear_all_stats — clears the statistics counters. 100GE MAC+PCS with Optional (528,514) RS-FEC or (544,514) RS-FEC and Adaptation Flow Hardware Design Example
loop_on — turns on internal serial loopback; loop_off — turns it off. 100GE MAC+PCS with Optional (528,514) RS-FEC or (544,514) RS-FEC and Adaptation Flow Hardware Design Example
To configure the packet generator for a fixed-size packet, use these registers:
0x1008 (Packet Size Configure) — bits [10:0] specify the transmit packet size in bytes. 10GE/25GE Design Examples Registers
0x1009 (Packet Number Control) — specifies the number of packets to transmit from the packet generator (HW reset value = 0xA). E-Tile Hard IP Intel® Stratix® 10 Design Examples User Guide: Ethernet, CPRI PHY, and Dynamic Reconfiguration
0x1010 (PKT_GEN_TX_CTRL) — bit [1] is the packet generator disable bit (write 1 to turn off, 0 to turn on); bits [5:4] = 01 selects fixed mode; bit [6] = 1 enables using register 0x1009 to stop the generator after a fixed packet count. E-Tile Hard IP Intel® Stratix® 10 Design Examples User Guide: Ethernet, CPRI PHY, and Dynamic Reconfiguration
Switching Between 10G and 25G Rates (Dynamic Reconfiguration)
The 10G/25G Ethernet Dynamic Reconfiguration design example demonstrates a dynamic reconfiguration solution for Stratix 10 devices using the E-Tile Hard IP for Ethernet IP core, supporting variants including 25GE with RS-FEC and PTP, 25GE, 10GE, and 1GE. 10G/25G Ethernet Dynamic Reconfiguration Design Examples
The high-level procedure for each rate switch transition is:
Assert (toggle) the sl_tx_rst_n and sl_rx_rst_n reset signals. 10GE/25GE MAC+PCS with RS-FEC Simulation Dynamic Reconfiguration Design Example Components
Disable SERDES using PMA attribute code 0x0001. 10GE/25GE MAC+PCS with RS-FEC Simulation Dynamic Reconfiguration Design Example Components
Trigger PMA analog reset. 10GE/25GE MAC+PCS with RS-FEC Simulation Dynamic Reconfiguration Design Example Components
Change the transceiver TX bit/refclk ratio to the destination rate (refclk = 156.25 MHz), then change the transceiver RX bit/refclk ratio to the destination rate (refclk = 156.25 MHz). 10GE/25GE MAC+PCS with RS-FEC Simulation Dynamic Reconfiguration Design Example Components
Reconfigure the registers for the Ethernet, RS-FEC, and transceiver blocks — the details of the changed register values are in the c3_reconfig.c file generated with the design example. 10GE/25GE MAC+PCS with RS-FEC Simulation Dynamic Reconfiguration Design Example Components
Adjust the phase offset of the recovered clock using PMA attribute code 0x000E. 10GE/25GE MAC+PCS with RS-FEC Simulation Dynamic Reconfiguration Design Example Components
Re-enable SERDES using PMA attribute code 0x0001. 10GE/25GE MAC+PCS with RS-FEC Simulation Dynamic Reconfiguration Design Example Components
Deassert sl_tx_rst_n and sl_rx_rst_n, then for 10G/25G DR transitions wait for PIO_OUT[4:0] = 0x1F (o_sl_tx_ptp_ready, o_sl_rx_pcs_ready, o_tx_pll_locked, o_sl_tx_lanes_stable, o_sl_rx_ready, o_sl_ehip_ready all asserted). 10GE/25GE MAC+PCS with RS-FEC Simulation Dynamic Reconfiguration Design Example Components
Good day.
Just wanted to check with you, is your concern has been addressed?
Feel free to let me know if you have further query. Happy to help.Regards,
Pavee - paveetirrasrie_Altera
Your part number is 1ST085EN2F43I2LG. This is a Stratix 10 E-tile device (TX variant).
The 25G Ethernet Intel FPGA IP supports Stratix 10 L- and H-tile devices only. Stratix 10 devices with both E- and H-tile transceivers are supported, but the IP core can only utilize the H-tile transceiver. Since your device is an E-tile TX part, this soft IP is not the right choice.
The E-Tile Hard IP for Ethernet is the correct IP for your board. It is the hard IP designed for your E-tile device, natively supports 10G/25G dynamic reconfiguration, RS-FEC (on 25G), MAC statistics counters, PTP timestamping, and packet generation/checking, all the features your test board requires.
Pavee
