8 port 10/25G ethernet interface in Stratix 10
The ip generates seperat P and N signals of the serial TX and RX lanes as,
o_tx_serial, o_tx_serial_n, i_rx_serial, i_rx_serial_n
I gave pin location assignments to these pins.
But Quartus 2026.1 says
Critical Warning(25196): A programming file will not be generated because the assembler identified user pins missing pin location assignments. Refer to the I/O Assignment Warnings table in the fitter report for a list of unassigned pins. You can assign these pins in the Pin Planner tool and recompile to allow programming file generation to pass.
In the fitter list it lists o_tx_serial_n and i_rx_serial_n
How to give pin assignment to these dedicates transiver lines.
Can you try to just assign o_tx_serial and i_rx_serial and run the compilation, let the Quartus to auto assign the N signals.
Kindly do let me know if that works.
Pavee
