Sajeev_antony
1 month ago8 port 10/25G ethernet interface in Stratix 10
We have custom board made with Stratix 10 1ST085EN2F43I2LG. The board has 8 SFP28 ports the needs to talk to 10/25G ethernet devices. This board is used to test the connected devices by sending a fix...
paveetirrasrie_Altera
1 month agoHello,
Your part number is 1ST085EN2F43I2LG. This is a Stratix 10 E-tile device (TX variant).
The 25G Ethernet Intel FPGA IP supports Stratix 10 L- and H-tile devices only. Stratix 10 devices with both E- and H-tile transceivers are supported, but the IP core can only utilize the H-tile transceiver. Since your device is an E-tile TX part, this soft IP is not the right choice.
The E-Tile Hard IP for Ethernet is the correct IP for your board. It is the hard IP designed for your E-tile device, natively supports 10G/25G dynamic reconfiguration, RS-FEC (on 25G), MAC statistics counters, PTP timestamping, and packet generation/checking, all the features your test board requires.
Pavee
