11 years ago
Need Help to Verify Timing Constraints On Output Pins to External Device
I'm relatively new in FPGA designing, so forgive me if my question seem simple.
The project I am working on involves using a Cyclone V to control 4 external DDS chips (AD9915). So I'm using the FPGA pins to send data to the DDS chips. I wish to clock my design at 156.25 MHz (which is period of 6.4 ns).
These DDS chips supply the 156.25 MHz clocks that I am using to clock my design in the FPGA. The DDS chip requires a setup time of 2 ns and hold time of 0 ns. (http://www.analog.com/static/imported-files/data_sheets/ad9915.pdf [pg 6])
I have read many reference online that specifies that a virtual clock has to be created for the 'set_output_delay' command to reference to. So just taking four pins from my design as an example, the SDC file looks like this. i have just attached a register with a constant value to these output ports just to verify the sdc file, also i put a 0 ns for setup and hold for the external device just to verify.
// These are the actual clock coming into the FPGA from the DDS
create_clock -name {ddsclk1} -period 6.400 -waveform { 0.000 3.200 } [get_ports {dds_clk_1}]
create_clock -name {ddsclk2} -period 6.400 -waveform { 0.000 3.200 } [get_ports {dds_clk_2}]
create_clock -name {ddsclk3} -period 6.400 -waveform { 0.000 3.200 } [get_ports {dds_clk_3}]
create_clock -name {ddsclk4} -period 6.400 -waveform { 0.000 3.200 } [get_ports {dds_clk_4}]
// These are virtual clocks I set up
create_clock -name {ddsclk1_ext} -period 6.400 -waveform { 0.000 3.200 }
create_clock -name {ddsclk2_ext} -period 6.400 -waveform { 0.000 3.200 }
create_clock -name {ddsclk3_ext} -period 6.400 -waveform { 0.000 3.200 }
create_clock -name {ddsclk4_ext} -period 6.400 -waveform { 0.000 3.200 }
// and then the setup time and hold time (I have set them to 0 just to verify)
set_output_delay -clock { ddsclk1_ext } -max 0.000 [get_ports {func_pin_1[0]}]
set_output_delay -clock { ddsclk1_ext } -max 0.000 [get_ports {func_pin_1[1]}]
set_output_delay -clock { ddsclk1_ext } -max 0.000 [get_ports {func_pin_1[2]}]
set_output_delay -clock { ddsclk1_ext } -max 0.000 [get_ports {func_pin_1[3]}] ......... and the same thing for ddsclk2,3,4_ext for func_pin_2,3,4
set_output_delay -clock { ddsclk1_ext } -min 0.000 [get_ports {func_pin_1[0]}]
set_output_delay -clock { ddsclk1_ext } -min 0.000 [get_ports {func_pin_1[1]}]
set_output_delay -clock { ddsclk1_ext } -min 0.000 [get_ports {func_pin_1[2]}]
set_output_delay -clock { ddsclk1_ext } -min 0.000 [get_ports {func_pin_1[3]}] ......... and the same thing for ddsclk2,3,4_ext for func_pin_2,3,4
I have also set the false paths between the four clock domains. However, when I compile my very simple design and run TimeQuest, TimeQuest reports that my setup slacks for ddsclk1,2,3,4_ext are negative. I find these strange and would expect Cyclone V to be able to run at much faster speed than 156.25 MHz, moreover my design now is just a reg to the output port.
http://www.alteraforum.com/forum/attachment.php?attachmentid=10148&stc=1
So, I am suspecting that I did not constrain the design properly. Hope anyone can give their two cents on the way I did the timing constraints.
Thanks in advance!
