11 years agoNeed Help to Verify Timing Constraints On Output Pins to External Device
Hi, I'm relatively new in FPGA designing, so forgive me if my question seem simple. The project I am working on involves using a Cyclone V to control 4 external DDS chips (AD9915). So I'...
11 years agoHi kaz. I couldn't do any test yesterday. But I still don't understand if it's correct to have a slack time greater than half a period in the DDR case.
I think the data valid window to sample the data should be less than half a period because if not I might be sampling data with the incorrect edge. I will be simplifying the interface to analyze an SDR transfer case to see if and understand the results I get. Thanks a lot.
