17 years ago
merging VHDL and Verilog code
Can anyone help whith how to merge VHDL code and Verilog code together?
in somehow i have to combine VHDL and Verilog code??
    --- Quote Start ---
    Quartus web edition or modelsim web edition (I don't remember) is restricted to use only ONE language.
    --- Quote End ---
    Quartus II Web Edition does support mixed languages.
    ModelSim-Altera Edition does NOT support mixed languages.
    :cool:
    sentronic,
    --- Quote Start ---
    I still don´t understand how I have to merge verilog and vhdl in a project?
    Could anyone give me a short example of how to merge in a project?
    --- Quote End ---
    assume you have design files in Verilog ( *.v ) and in VHDL ( *.vhd ). Simply add to your project in Quartus II.
    Use the menu: "project" and submenu "add/remove files in project..." to add the *.v and .vhd files to your project.
    When you create the files from scratch you can use: "file" and "new..." and select the appropriate file type Verilog or VHDL in the dialog window.
    Hope this helps
    Hi everybody,
    Thanks for all your replies.
    As I see "the example from parrado" gives, is a way of writing the same code in vhdl and verilog.
    Quartus Web edition is not restricted regarding mixed language programming. Otherwise many Altera Megafunctions wouldn't compile.
    --- Quote Start ---
    Hereby you should take notice that Verilog is case sensitive, while VHDL is not. So be careful to be consistent in naming.
    --- Quote End ---
    this is good advice to follow all the time. its painful to bring a project from Windows to Linux and deal with case sensitivity issues. :mad:
    Quartus-II allows for a fluent intermixing of VHDL, Verilog, and schematics on the level of "modules" in Verilog, "entity/architectures" in Verilog and Blocks in schematics.
    The naming and instantiation of the module in Verilog, entity/architecture in VHDL and blocks in schematics should be the same when using design entities among these different entry methods.
    Besides that also the names of input/outputs/ios (Verilog) and ports (VHDL) or pins in schematics should correspond.
    Hope this helps...
    You can instance from VHDL a Verilog module and viceversa, each one in different files. This example shows how do it:
    This is a VHDL entity called "White"
    ENTITY white IS
    PORT(
    ----------------------Inputs-------------------------------
    clk : IN STD_LOGIC;
    i_fval : IN STD_LOGIC;
    i_media : IN STD_LOGIC_VECTOR(9 DOWNTO 0);
    ----------------------Outputs--------------------------------
    o_enable : OUT STD_LOGIC;
    o_exposure : OUT STD_LOGIC_VECTOR(9 DOWNTO 0)
    END white;
    This is a Verilog code that instances a white module called white0
    white white0(
    .clk(CCD_PIXCLK),
    .i_fval(MEDIA_sfval[9:0]),
    .i_media(MEDIA_sa[9:0]),
    .o_enable(senable),
    .o_exposure(sbalance)
    If you are refering to a merge in the same file then this cannot be done. You would need to rewrite the Verilog functions into VHDL or the other way around!
    Quartus allows multiple languages so you should be able to use mixed Verilog and VHDL source files within your Quartus project
