17 years agomerging VHDL and Verilog code
Can anyone help whith how to merge VHDL code and Verilog code together? in somehow i have to combine VHDL and Verilog code??
17 years agosentronic,
--- Quote Start --- I still don´t understand how I have to merge verilog and vhdl in a project? Could anyone give me a short example of how to merge in a project? --- Quote End --- assume you have design files in Verilog ( *.v ) and in VHDL ( *.vhd ). Simply add to your project in Quartus II. Use the menu: "project" and submenu "add/remove files in project..." to add the *.v and .vhd files to your project. When you create the files from scratch you can use: "file" and "new..." and select the appropriate file type Verilog or VHDL in the dialog window. Hope this helps
