17 years agomerging VHDL and Verilog code
Can anyone help whith how to merge VHDL code and Verilog code together? in somehow i have to combine VHDL and Verilog code??
17 years agoYou can instance from VHDL a Verilog module and viceversa, each one in different files. This example shows how do it:
This is a VHDL entity called "White" ENTITY white IS PORT( ----------------------Inputs------------------------------- clk : IN STD_LOGIC; i_fval : IN STD_LOGIC; i_media : IN STD_LOGIC_VECTOR(9 DOWNTO 0); ------------------------------------------------------------- ----------------------Outputs-------------------------------- o_enable : OUT STD_LOGIC; o_exposure : OUT STD_LOGIC_VECTOR(9 DOWNTO 0) ------------------------------------------------------------- ); END white; This is a Verilog code that instances a white module called white0 white white0( .clk(CCD_PIXCLK), .i_fval(MEDIA_sfval[9:0]), .i_media(MEDIA_sa[9:0]), .o_enable(senable), .o_exposure(sbalance) );
