15 years ago
Max V Hardware Implementation
This is the first time I'm implementing a CPLD and so I came here looking for some advice. The following schematics show how I've wired the JTAG connector and also the bypass caps. I intend to run all IO banks at 3.3V.
http://i.imgur.com/z1ReB.png
http://i.imgur.com/LEpF4.png
And this is the PCB layout:
http://imgur.com/VDyPd.png
Things I'm looking for advice on:
  1. Bypass Cap Position and Values.
  2. Power Distribution Network - Is the broken ground plane ok?
  3. JTAG Pull Up/Down Resistor Values
A question regarding JTAG, specifically. The core voltage of the Max V is 1.8V - but I'm using the IO banks at 3.3V. Do I provide 3.3V to the JTAG header or 1.8V?
Please note that CPLD is intended to implement a 100 bit Shift Register. The frequency will be controlled by a MCU when it interfaces via SPI. I intend to use the slowest frequency (62.5kHz), so the requirements are not of a high speed digital design. However, I'd still like my design to be robust have high signal integrity.
I would appreciate any form of input on this matter.
