15 years agoMax V Hardware Implementation
This is the first time I'm implementing a CPLD and so I came here looking for some advice. The following schematics show how I've wired the JTAG connector and also the bypass caps. I intend to run al...
15 years agoHi,
JTAG pins are powered by the same VCCIO as the remaining pins on the I/O bank. So, in your case, 3.3V. I don't have the manuals at hand. The JTAG looks OK but... tripple check. At higher frequencies, return paths are important and having signals over plane cuts is a problem. But at 62.6 kHz, it's pretty much a matter of whatever.
