15 years agoMax V Hardware Implementation
This is the first time I'm implementing a CPLD and so I came here looking for some advice. The following schematics show how I've wired the JTAG connector and also the bypass caps. I intend to run al...
15 years ago --- Quote Start --- I had another question: None of the implemented logic in the CPLD requires an external oscillator. It's just a 100-bit shift register that sends data out serially when it receives a clock signal from a microcontroller. So, my question is - does the CPLD still need an external oscillator or can I have a fully working CPLD for my application without one? --- Quote End --- The only clocks you need are the ones your logic uses. There's no "hidden" need for clocks in the CPLD. So, if I understood your design correctly, the only clock signal you need is the SPI clock provided by the MCU. As Dave mentioned, the MAX V has an internal oscillator. However, it's frequency will vary depending on voltage, temperature and from chip to chip.
