15 years agoMax V Hardware Implementation
This is the first time I'm implementing a CPLD and so I came here looking for some advice. The following schematics show how I've wired the JTAG connector and also the bypass caps. I intend to run al...
14 years agoThose guidelines are intended to enable reliable high frequency operation; they also kind of assume you have a PCB with GND and power planes.
Of course, for 62 kHz operation, there's much less concern. But the general idea is to place the capacitors as close to the device as possible, using the shortest widest trace you can, with priority for the small high frequency capacitors.
