Nakaj's avatar
Nakaj
1 year ago
MAX V Exposed pad solder reflow problem
A reflow soldering failure occurred on the exposed pad on the bottom of the QFP64
pin device of the MAX V device. Please let me know if there is a recommended
pattern layout for Exposed Pad.
Please let me know if there is a recommended value for the number and diameter of
through holes to connect the exposed pad to the GND pattern.
  • Thanks for your response, I now transition this thread to community support. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
  • FakhrulA_altera's avatar
    FakhrulA_altera
  • Nakaj's avatar
    Nakaj
    Thank you for your reply.
    We decided not to do the rework due to customer request.
    This concludes my questions.
    Nakaj
    FakhrulA_altera
    Hi Nakaj,
    Apologies for the delay due to the end-year and New Year holidays. As mentioned in the AN353, you may refer to the latest IPC-A-610D Standard.
    Fakhrul
    • Nakaj's avatar
      Nakaj
      Thank you so much for your reply.
      But my question is still not resolved.
      Please tell me the temperature and heating time of the heater when removing the IC. How can I evaluate the effect on the circuit components on the back side of the IC to be removed?
      Nakaj
  • Nakaj's avatar
    Nakaj
    Please let me know manufacturer's recommended conditions for MAX V rework(IC mounting by hand soldering).
    For example,heating temperature, heating time, tools etc.
    Is there a risk of overheating the IC during rework? (Deterioration, impact on lifespan, etc.)
    Nakaj
  • FvM's avatar
    FvM
    stencil thickness is usually chosen by the assembly service provider depending on PCA technology and used pad range. As mentioned above, problem with EQFP package is the 0.05 to 0.15 mm range of exposed pad clearance. If the parts have typical 0.1 mm clearance, 120 µm standard stencil thickness should work, but for maximal 0.15 clearance you'll probably want a thicker stencil, e.g. 180 µm if it's still compatible with small pads used on the board.
    I'm presuming that you have industry standard reflow profile as suggested in AN353, because another possible reason for solder failure is "cold solder joint".
    Frank
    • Nakaj's avatar
      Nakaj
      your answer is very helpful.
      Nakaj
    • Nakaj's avatar
      Nakaj
      I would like to know about recommended thickness of the solder mask(stencil?) of MAX V QFP64 device.
      About reccomended pattern layout for PCB, I found a Cadence and mentor graphics CAD data in Intel website.
      PCB design engineer tries to analyse it.
      Nakaj
  • Nakaj's avatar
    Nakaj
    If you find a solution please let me know.
    Nakaj
    • Nakaj's avatar
      Nakaj
      But I would like to know about reccomended pattern layout for PCB and recommended thickness of the solder mask of MAX V QFP64 device.
      Nakaj
  • FvM's avatar
    FvM
    what kind of failure do you observe, missing connection or short to other pins?
    I see a previous discussion related to 64-pin EQFP package https://community.intel.com/t5/Programmable-Devices/Max-V-Stencil-Design-64-Pin-Plastic-Enhanced-Quad-Flat-EQFP/m-p/1574520#M94757
    I think, a comfortable option is to place vias beneath the exposed pad, this way you don't need to care for solder drain through vias. As mentioned in my previous post, EQFP package has the problem of clearance tolerance between pad and PCB, about 0.05 to 0.15 mm. You need to supply suffient solder paste to safely bridge the gap.
    Frank
    • Nakaj's avatar
      Nakaj
      Please also tell me the recommended thickness of the solder mask.
      Nakaj
    • Nakaj's avatar
      Nakaj
      We have an issue with exposed pad not being connected. There may not be enough solder.
      Is there reccomended pattern layout for PCB?
      Nakaj
