MAX V Exposed pad solder reflow problem
- 1 year ago
Thanks for your response, I now transition this thread to community support. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
what kind of failure do you observe, missing connection or short to other pins?
I see a previous discussion related to 64-pin EQFP package https://community.intel.com/t5/Programmable-Devices/Max-V-Stencil-Design-64-Pin-Plastic-Enhanced-Quad-Flat-EQFP/m-p/1574520#M94757
I think, a comfortable option is to place vias beneath the exposed pad, this way you don't need to care for solder drain through vias. As mentioned in my previous post, EQFP package has the problem of clearance tolerance between pad and PCB, about 0.05 to 0.15 mm. You need to supply suffient solder paste to safely bridge the gap.
Frank
Please also tell me the recommended thickness of the solder mask.
Nakaj
