XQSHEN's avatar
XQSHEN
6 years ago
How to set timing constraint to uart
uart is used as interface of external device. And this device has it's owner clock. When doing timing constraint, should I set uart rxd and txd as false path? or setting timing constraint using virtual clock? or just set max delay?
  • KhaiChein_Y_Intel's avatar
    KhaiChein_Y_Intel
    We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
    KhaiY
    KhaiChein_Y_Intel
    If they are asynchronous, you may set false path or set multicycle if they are synchronous.
    KhaiY
    KhaiChein_Y_Intel
    Do you mean there is no direct relationship between the FPGA clock and external clock? Could you elaborate?
    KhaiY
    • XQSHEN's avatar
      XQSHEN
      Yes. They are two individual device using uart to communicate.
      FPGA ------uart---------external device(wifi module).
      • XQSHEN's avatar
        XQSHEN
        1. FPGA has its own clock
        2. Wifi module has its own clock
    • XQSHEN's avatar
      XQSHEN
      as there is no directly between FPGA clock and external device clock, how do you define the max or min limit?
