XQSHEN
6 years agoHow to set timing constraint to uart
uart is used as interface of external device. And this device has it's owner clock. When doing timing constraint, should I set uart rxd and txd as false path? or setting timing constraint using virt...
KhaiChein_Y_Intel
5 years agoHi,
You may constrain the I/O signal max and min delay with reference to the virtual clock and any timing exceptions if applicable. You may refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_timequest_cookbook.pdf (Page 9 I/O Constraints)
KhaiY
XQSHEN
5 years agoas there is no directly between FPGA clock and external device clock, how do you define the max or min limit?
