XQSHEN
6 years agoHow to set timing constraint to uart
uart is used as interface of external device. And this device has it's owner clock. When doing timing constraint, should I set uart rxd and txd as false path? or setting timing constraint using virt...
KhaiChein_Y_Intel
5 years agoHi,
Do you mean there is no direct relationship between the FPGA clock and external clock? Could you elaborate?
KhaiY
