lambert_yu's avatar
lambert_yu
2 years ago
How to disable lvds output in arria 10 chip dynamically?
Hi, all
fpga: arria 10
quartus II: 18.0 standard
I have requirement for the lvds ip, when I have no data output, I need to disable lvds pin dynamically. So I add below design:
tx_serdes tx_serdes_inst(
.inclk (clk),
.rst (rst),
.data (data),
.tx_coreclock(usr_clk),
.data_o (data_lvds) //io standard : "lvds"
assign data_o = oe ? data_lvds : 1'bz;
From this Why do I see functional errors in hardware when implementing... (intel.com), I know there's bug and from this information, I don't know if there's chance to disable the lvds output?
If not, how could disable lvds output dynamically? If yes, is there chance to modify this issue in quartus II 18.0? Or I need to use the quartus 22.0 or later version?
BRs,
Lambert
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you.
    AqidAyman_Altera
    Hi Lambert,
    Do you have any update on what being asked by @FvM?
    Do you still need help on this?
    Aqid
    • lambert_yu's avatar
      lambert_yu
      Hi, Aqid
      Sorry for the delayed response.
      Current I think bus lvds solution is okay for our design. We will test again when we get the newest hardware design. Thanks.
      BRs,
      Lambert
  • FvM's avatar
    FvM
    not sure what you are trying to achieve. Seeing no output with OE=0 (output inactive) is expectable. A receiver on the bus might however read arbitary data (= noise) when no peer is driving the bus. You can try bias resistors as used in RS-485 to enforce a defined state of undriven bus.
      lambert_yu
      Hi, FvM
      Now I am just for testing one differential pair could used be either input or output when use bus lvds solution. And now just we have limited hardware resource, we connect two differential pairs to test the solution. And we didn't setup the external termination part (without series terminations). So I think your opinion is reasonable (arbitary data (= noise)). Thanks!
      BRs,
      Lambert
      lambert_yu
      Hi, Aqid
      I tried this solution, and I found that when I set the oe to low, there's no data on the bus. I used two diff pair to do this test. I found that there's one pad which input has random 0->1 or 1-> 0 toggle, and anothe didn't have when these two pad are all input and diff bus was not driven. I don't know why, could you help proide some information for this?
      my design: arria 10 (10ax115n3f45i2sg)
      one diff pair : (in 2j bank, which use the reference clock from its dedicated clk pin)
      pll instance1();
      gpio instance1(); (simple register mode)
      another diff pair: (in 2h bank, which use the reference clock from its dedicated clk pin)
      pll instance2();
      gpio instance2(); (simple register mode)
      pattern : 0101010...
      connection : these two diff pairs connected directly.
      BRs,
      Lambert
      lambert_yu
      Hi FvM,
      Thanks for your help.
      I found that there's one required choice (Use pseudo-differential buffer) in altera gpio ip. So if I use SSTL IO standard instead of POD io standard, there's no error, right?
      BRs,
      Lambert
