lambert_yu
Contributor
2 years agoHow to disable lvds output in arria 10 chip dynamically?
Hi, all fpga: arria 10 quartus II: 18.0 standard I have requirement for the lvds ip, when I have no data output, I need to disable lvds pin dynamically. So I add below design: tx_ser...
- 2 years ago
LVDS IO-standard has no tri-state feature, independent of FPGA series or Quartus version. You can refer to BLVDS (bus LVDS) if it's fast enough. On Arria 10, there's no BLVDS choice available, you'll use differential SSTL instead.
FvM
2 years agoLVDS IO-standard has no tri-state feature, independent of FPGA series or Quartus version. You can refer to BLVDS (bus LVDS) if it's fast enough. On Arria 10, there's no BLVDS choice available, you'll use differential SSTL instead.
- lambert_yu2 years ago
Contributor
Hi FvM,
Thanks for your help.
I found that there's one required choice (Use pseudo-differential buffer) in altera gpio ip. So if I use SSTL IO standard instead of POD io standard, there's no error, right?
BRs,
Lambert
