Stratix III FPGA Development Kit
"Hello!
I am currently facing an unusual issue when trying to use the Stratix III FPGA Development Kit. After installing Quartus II 13.1 Subscription Edition (the last version supporting the Stratix III family) along with the respective device files (.qdz) for Cyclone, Arria, and Stratix III, and properly configuring the license on Windows 11, the Stratix III family does not appear in the device selection wizard. Interestingly, the Quartus Device Installer states that the family is already installed, but it remains hidden inside the software.
To isolate the issue, I have tested multiple operating systems and Quartus versions, but the problem persists:
1) Windows 11 & Windows 7 (Quartus II 13.1, 13.0, and 12.1 Subscription): Arria and Cyclone families work perfectly. Stratix III shows as installed in the device manager but is unavailable inside Quartus.
2) Windows 7 (Quartus II 9.0 Web Edition): The Stratix III family appears in the family selection menu in Quartus, but our specific device (EP3SL150F1152) is listed as unsupported.
3) Ubuntu 12.04 (Quartus II 13.1 Subscription): Same behavior as Windows; the installer claims it is there, but Quartus does not show it.
Given these cross-platform results, I suspect the root cause might be:
1) A corrupted or flawed Stratix III device installer file (.qdz).
2) A licensing restriction, where our current license might need a specific feature enabled for the Stratix III family, even though the software allows the installation.
Could you please guide me on how to get this Stratix III Development Kit operational (which features the EP3SL150F1152 device)?"
Thank you for your time and assistance. I look forward to your guidance.
Best regards!
- FakhrulA_altera
Thank you for the detailed information.
Since the issue is seen across multiple OS versions, this looks more likely related to the Quartus device package installation rather than the board itself. There is also a similar case where Stratix III did not appear in Quartus 13.1 even though it showed as installed, and the recommendation was to reinstall using the correct .qdz file from the Individual Files tab.
https://www.altera.com/downloads/fpga-development-tools/quartus-ii-subscription-edition-design-software-version-13-1-windowsPlease try the following:
1. Remove the current Stratix III device support and reinstall using the matching Stratix III .qdz file.
2. Make sure the device installer is pointing to the correct file and folder. Older Quartus II 13.1 cases also showed that device file naming or installation path issues can prevent proper detection.
For reference, Stratix III is a supported device family in Quartus II 13.1, and the EP3SL150 device is part of the Stratix III family.
Fakhrul
- bsneves
Dear Support,
I have already tried renaming the device installation file, but the Quartus 13.1 device installer does not accept any name other than "stratixiv-13.1.0.162.qdz". When I use this default name, a window appears with the checkboxes ticked for the Stratix III family (indicating it is already installed). I cannot uncheck these boxes to uninstall only this specific family. I was also careful to place the .qdz file inside a folder with a simple name—without spaces or special characters—as I am aware of this classic Quartus 13.1 bug. Even so, nothing seems to solve the problem, and I am truly at a loss as to what might be going wrong. I am happy to make my machine available for you to take a closer look at the issue using TeamViewer, AnyDesk, or any other remote access tool.
- KennyT_altera
May I know what OS that you are using to install the Quartu 13.1?
- FakhrulA_altera
As we haven't received a response to our previous notification, this thread will be transitioned to community support. We hope all your concerns have been addressed. If you have any new questions, please feel free to open a new thread to receive support from Altera experts. Otherwise, community users will continue to assist you here. Thank you.
- bsneves
I am following up on the message I sent on July 9th.
I apologize for the delay in getting back to you, as I have been overwhelmed wrapping up the academic semester.
We still haven't found a solution for our setup. I cannot get our Stratix III kit up and running because Quartus requires a specific license that unlocks the Stratix device family. Could you please provide step-by-step instructions on how to generate this license?
Bruno - FakhrulA_altera
Hi Bruno,
Thank you for your follow-up.Based on the license type previously shared, SW-QUARTUS-WE-FIX is a Quartus II Web Edition license. It cannot enable Stratix III in Quartus II 13.1 Subscription Edition, even if the Stratix III/IV device package is installed.
You do not need to purchase a license if Quartus II Web Edition meets your requirements. Please install and use Quartus II Web Edition 11.0 SP1 with your existing Web Edition license. Stratix III is supported in that release, and the EP3SL150F1152 device is supported.
If your project specifically requires Quartus II 13.1 Subscription Edition, then a valid Subscription Edition license with Stratix III device support is required. In that case, please contact an authorized Altera distributor to discuss available license options.The stratixiv-13.1.0.162.qdz file is the correct device package for Stratix III/IV in Quartus II 13.1.
Fakhrul
