Help with statemachine/verilog
Hello to everyone, i am having a lot of trouble to work with state machines using verilog!
here is my code
module maquina_irig
clk_mi,
rstn_mi,
zero_mi,
um_mi,
p_mi,
dez_mi,
ts_mi,
sinal_mi
input clk_mi; // 20mhz from top
input rstn_mi; // reset from top
input zero_mi; // sinais irig com temporizacao
input um_mi;
input p_mi;
input dez_mi;
input ts_mi; // timestamp
output sinal_mi; //sinal de saida
wire ts_mi;
reg sinal_mi;
reg current_state, next_state;
parameter idle = 0, send_p = 1, seconds =2;
always @ (posedge clk_mi or negedge rstn_mi)
if (~rstn_mi)
begin
current_state <= idle;
end
else
begin
current_state <= next_state;
end
always @ (posedge clk_mi)
begin
next_state = current_state;
case (current_state)
idle: next_state = send_p;
send_p: next_state = seconds;
seconds: next_state = idle;
default: next_state = idle;
endcase
end
begin
sinal_mi = 0;
idle: ;
send_p: sinal_mi = p_mi;
seconds: ;
default: ;
endcase
end
endmodule
I am having those errors
Error (10028): Can't resolve multiple constant drivers for net "next_state" at maquina_irig.v(61)
Error (10029): Constant driver at maquina_irig.v(41)
Any light in this darkness i am ? Thanks for the help.. Also if someone happens to know of any material about this subject i would be really thankful!10 Replies
The error is caused by simple violation of Verilog syntax
--- Quote Start --- but now my state machine has 20 states, where 10 of them is just a replicated state --- Quote End --- The other option is to use hiearchical state machines, in this case a simple sub state machine to perform a particular action, that is needed multiple times. - Altera_Forum
Actually i have my counters that generate my timestamp and i am using my it to generate an IRIG-B signal
this time machinal is to generate the irig-b signal. Is a little bit more complex than simple counters and my boss told me to do using state machines :D It's working now throught.. Thanks a lot for the support! - Altera_Forum
I'm not sure if I understood what the statemachine is supposed to do but if this is just a realtime timer for keeping track of year:days:hours:minutes:seconds then I would just implement this as a bunch of modulo counters. When the 'second' counter hits 60 that enables the 'minute' counter to increment. Likewise when the 'minute' counter hits '60' you enable the 'hour' counter to increment.
With separate counters you are just implement a bunch of simple but separate state machines. This approach is much easier since the state transitions become trivial because you are not trying to encode it all into one state machine. - Altera_Forum
--- Quote Start --- You apparently intend to send them sequentially. Using two states is the siimplest way.. --- Quote End --- Yes i've done that, but now my state machine has 20 states, where 10 of them is just a replicated state F.E
I need to verify the bits on a byte reponsable for the seconds, then send a "p_mi" signal, and it goes like this untill years! seconds->p_mi->minuts->p_mi->hours-> ....... ->years All the p_before (minute/hour..etc) has the same code Same applies for the hour/minut etc.. .. Is there some way to do a simplification? Thanks for the supportSECOND: begin if(ts_mi==0) sinal_mi <= zero_mi; else if(ts_mi==1) sinal_mi <= um_mi; end P_BEFORE_MINUTE: begin sinal_mi <= p_mi; end - Altera_Forum
--- Quote Start --- Quartus II has a template menu option with some state machine implementations that you can look at. With a verilog or VHDL file open got to Edit --> Insert Template and choose the one you want to use. --- Quote End --- Thanks for the tip. I am using the Moore state machine now. My output is a 1bit reg. I want to send in one state two signals, "1" and "0" in the same state How can i do that? I can't just do Initial_State: begin out<= 1; out<= 0; end right? Thanks.. - Altera_Forum
Do you have any text book suggestion?
Thanks for the help. - Altera_Forum
The error is caused by simple violation of Verilog syntax. You can't drive the variable next_state in more than one place.
But it's completely unclear, why you did it all. Apparently you have copied second always block without thinking. The assignment next_state = current_state; in the third always block is simply useless. In addition, assigning both next_state and current_state in an edge sensitive always block is far from a reasonable FSM design. It causes an unwanted delay of one clock cycle and possibly strange behaviour. I suggest to use FSM examples from a Verilog text book as astarting point.
